ReferenceIntersector working weird
Message 1 of 12
The following code works doesn't works for walls but not for pipes and ducts:
    public Dictionary<Reference, XYZ> GetIntersectPoints(
  Document doc,
  XYZ  ff,XYZ ff1)
            // Find a 3D view to use for the
            // ReferenceIntersector constructor.
            FilteredElementCollector collector
              = new FilteredElementCollector(doc);
            Func<View3D, bool> isNotTemplate = v3
              => !(v3.IsTemplate);
            View3D view3D = collector
              .OfClass(typeof(View3D))
              .Cast<View3D>()
              .First<View3D>(isNotTemplate);
            // Use location point as start point for intersector.
            XYZ startPoint = ff;
            XYZ endPoint = ff1;
            // Shoot intersector along element.
            XYZ rayDirection = endPoint.Subtract(
              startPoint).Normalize();
            List<BuiltInCategory> builtInCats
              = new List<BuiltInCategory>();
            builtInCats.Add(BuiltInCategory.OST_Walls);
            builtInCats.Add(BuiltInCategory.OST_PipeCurves);
            builtInCats.Add(BuiltInCategory.OST_DuctSystem);
            ElementClassFilter filter = new ElementClassFilter(typeof(PipeSegment));
            ElementMulticategoryFilter intersectFilter
              = new ElementMulticategoryFilter(builtInCats);
            ReferenceIntersector refIntersector = new ReferenceIntersector(intersectFilter, FindReferenceTarget.Element, view3D);
            //ReferenceIntersector refIntersector = new ReferenceIntersector(view3D);
            //refIntersector.TargetType = FindReferenceTarget.Face;
            //ReferenceIntersector refIntersector = new ReferenceIntersector(filter, FindReferenceTarget.Element, doc.ActiveView);
            refIntersector.FindReferencesInRevitLinks = true;
            IList<ReferenceWithContext> referencesWithContext
              = refIntersector.Find(startPoint,
                rayDirection);
            IList<XYZ> intersectPoints = new List<XYZ>();
            IList<Reference> intersectRefs
              = new List<Reference>();
            Dictionary<Reference, XYZ> dictProvisionForVoidRefs
              = new Dictionary<Reference, XYZ>();
            foreach (ReferenceWithContext r in
              referencesWithContext)
                TaskDialog.Show("iipl", doc.GetElement(r.GetReference().ElementId).Name);
                dictProvisionForVoidRefs.Add(r.GetReference(),
                  r.GetReference().GlobalPoint);
            return dictProvisionForVoidRefs;
Thanks & Regards
Sanjay Pandey
Replies (11)
Message 2 of 12
aignatovich
Hi!
The first problem could be that the elements, you expect to find with ReferenceIntersector are not visible in the 3D view you've founded in the model, the second problem is just for ducts, you should use BuiltInCategory.OST_DuctCurves instead of BuiltInCategory.OST_DuctSystem.
I've played with Revit Python shell:
pipe = selection[0]
point = pipe.Location.Curve.Evaluate(0.5, True)
direction = XYZ.BasisZ
rayOrigin = point - 5 * direction
filter = ElementCategoryFilter(BuiltInCategory.OST_PipeCurves)
refIntersector = ReferenceIntersector(filter, FindReferenceTarget.Element, doc.ActiveView);
elemRef = refIntersector.FindNearest(rayOrigin, direction)
print elemRef
it works as expected
Message 3 of 12
Tried BuiltInCategory.OST_DuctCurves but in vain.
The elements are surely visible. I have wall , duct and pipes in main file and also in linked revit file,
The code works fine if it intersects wall but not in case of ducts or pipes even if the elements are in main file still no result is retutned.
Result is returned if its a wall
Thanks & Regards
Sanjay Pandey
Message 4 of 12
Revitalizer
may it be that the View3D doesn't show Pipe or Duct Elements?
According to your code, you take the first one you can get.
It its DetailLevel is Coarse, may it be that there is no 3D Duct/Pipe geometry to be hit at all?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 12
aignatovich
Hi again!
You should check:
a) elements visibility. Are you sure, that elements are visible? According to your code, you just find first 3d View
b) view detail level
I created family to setup ray direction, and again, it works perfect (look at the attached picture):
targetFamily = selection[0]
transform = targetFamily.GetTotalTransform()
direction = transform.BasisZ
rayOrigin = transform.Origin
filter = ElementCategoryFilter(BuiltInCategory.OST_DuctCurves)
print elemRef
But, if view detail level is set to coarse, nothing found.
Message 6 of 12
Pipe or Duct Elements is clearly visible in 3d view. and details level is Fine too.
I think issue is something else because how come its find the wall if its intersecting
Thanks & Regards
Sanjay Pandey
Message 7 of 12
aignatovich
May be something wrong with your ray origin and direction?
Message 8 of 12
I think I am getting in right direction.
Did some R&D.
I changed the offset of the  pipes and ducts to 0 and now the code works.
In my function
  Document doc,
  XYZ  ff,XYZ ff1)
for XYZ ff and XYZ ff1 I am prompting user to pick point
 XYZ l1 = uidoc.Selection.PickPoint();
  XYZ l2 = uidoc.Selection.PickPoint();
and in both the points z values are zero.
so this is the culprit.
Now I need to think how do I get both points which includes Z value also.
Thanks & Regards
Sanjay Pandey
Message 9 of 12
aignatovich
PickPoint prompts the user to pick a point on the active work plane.
Perhaps you should prompt user to select model line instead
Message 10 of 12
But I fail to understand why PickPoint is not returning the Z value.
It is bound to do so.
Thanks & Regards
Sanjay Pandey
Message 11 of 12
aignatovich
Message 12 of 12
Thanks for all the time and effort.
I have now modified the code so that its prompts the user to select the element and that worked.
Thanks & Regards
Sanjay Pandey
