Reference Plane to Section - Dyanmo
nicolLSPDR
nicolLSPDR
I’m trying to make a dynamo script that grabs the reference planes in the project and creates a section view for all obtained reference planes. I'm struggling to get the bounding box to generate the section without breaking. Any ideas?
RLY_15
Exporting the workspace for clarity, will edit post shortly.
RLY_15
1. Your Vector Z-Axis offset should be a Plane.Normal offset instead so that it always generates a bounding box depth.
2. You have your min/max point inputs swapped. The node expects the min point to have the smaller x/y/z values.
nicolLSPDR
I'm not sure if this is the approach you are talking about but I keep running into an error where I get a null point randomly at either geometry translate nodes. The nodes work fine up until I connect them to section view node. RPSections_2026-05-04_02-58-36.png
