Recursive get elements in Group
I would like to get all Elements in a Model Group. The catch is, even elements which are in a nested group of the Model Group given. Is there an existing method i could use?
Does Group.GetMemberIds() contain a flat list of ALL the elementids recursivly?
First draft to getting Elements recursive from a Group
        public static List<RevitElement> GetMembersRecursive(Document d, RevitGroup g, List<RevitElement> r)
            List<RevitElement> elems = g.GetMemberIds().Select(q => d.GetElement(q)).ToList();
            foreach (RevitElement el in elems)
                if (el.GetType() == typeof(RevitGroup))
                    Upload.GetMembersRecursive(d, el as RevitGroup, r);
                    continue;
                r.Add(el);
            return r;
OR_AND_NO
Could You please explain what is Upload in Your code?
Upload is just the class name.
You could use it without the class name.
class GroupUtil
        public static List<Element> GetMembersRecursive(Document d, Group g, List<Element> r = null)
            if (r == null)
                r = new List<Element>();
            List<Element> elems = g.GetMemberIds().Select(q => d.GetElement(q)).ToList();
            foreach (Element el in elems)
                if (el.GetType() == typeof(Group))
                    GetMembersRecursive(d, el as Group, r);
                    continue;
                r.Add(el);
            return r;
DavidsDesk
I'm working on the same problem and find this post very helpful.  I have a DocumentChanged event argument, but I'm getting an error LIST<Element> does not contain definition for "GetMembersRecursive."
    public class OnGroupTrans : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            return Execute(commandData.Application);
        public Result Execute(UIApplication uiapp)
            // Get the handle of current document.
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uiapp.ActiveUIDocument.Document;
            // Get the element selection of current document.
            Selection selection = uidoc.Selection;
            ElementId selectedIds = (ElementId)selection.GetElementIds();
            Group selectedGroup = (Group)doc.GetElement(selectedIds);
            // Get a list of group elements
            ElementClassFilter filter = new ElementClassFilter(typeof(Group));
            List<Element> groupElem = (List<Element>)selectedGroup.GetDependentElements(filter);
            List<Element> groupMem = groupElem.GetMembersRecursive();
            return Result.Succeeded;
asnow_DSARCSVY7W37
Why does
"query": "'property.name.Edited by' != null and 'property.name.Edited by' != ''"
return
"results": [
                                "name": "Edited by",
                                "value": null
Is the 'and' looking for an =is= like some other graphQL implementations use?
