Hi, Im to Revit API but I have been searching regarding this for a while. Is there any functionality in the API to recreate a certain object if you have a json of this object.
For example:
Using the Revit API I can get a selected TextNote as an object. If I serialize this into a Json, am I able to recreate this using the Revit API without hardcoding the api call to recreate this TextNote?
Grasshopper has this functionality where you can recreate objects from a json (https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Runtime_CommonObject_FromJSON_1.htm)
Is there anything similar in Revit API?
Thanks!
Developer Advocacy and Support +
