& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi, I have found that rebar which I make via CreateFromCurves is not folowing the curve which I pass to method. It looks that rebar surface is following the curve, not its centerline. I attached the picture where you can see blue line from dynamo (it's the same curve that I passed to method) and red one for rebar. Can someone explain me from where this weird behavior come from?
UPDATE: There is also difference between rebar created from CreateFreeForm method and CreateFromCurves. In the picture both bars are created from the same curve, and free form rebar is following curve exactly, the normal one is not.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
