Rebar Location Controlling
arshad.k
arshad.k
Hello Everyone!
  I try to create rebar using API, I choose CreateFromRebarShape Method for Creation. And I successfully created the rebar
but one thing, rebar which I have created is always placing outside of the host and I can't able to control the location of
rebar and its layout. Can anybody help in solving this.
I have attached my code and error image below.
#region Create Reabar in Shape Method
            using (Transaction createRebar = new Transaction(revitDoc, "Create Rebar"))
                createRebar.Start();
                //Pick Host Element
                Reference hostElementReference = revitUi.Selection.PickObject(ObjectType.Element);
                Element hostElement = revitDoc.GetElement(hostElementReference);
                //Select Planar Face to Place Rebar
                Reference selectedRefer = revitUi.Selection.PickObject(ObjectType.Face);
                PlanarFace plane=revitDoc.GetElement(selectedRefer).GetGeometryObjectFromReference(selectedRefer) as PlanarFace;
                //Get Rebar Shape
                RebarShape rebarShape = new FilteredElementCollector(revitDoc).OfClass(typeof(RebarShape)).Where(x => x.Name.Equals("M_08")).FirstOrDefault() as RebarShape;
                //Get Rebar Type
                RebarBarType rebarType = new FilteredElementCollector(revitDoc).OfClass(typeof(RebarBarType)).OfCategory(BuiltInCategory.OST_Rebar).Where(x => x.Name.Equals("10M")).FirstOrDefault() as RebarBarType;
                //Create Rebar
                Rebar bar = Rebar.CreateFromRebarShape(revitDoc, rebarShape, rebarType, hostElement, plane.Origin, plane.XVector, plane.YVector);
                //Create Layout
                RebarShapeDrivenAccessor rebarShapeDrivenAccessor = bar.GetShapeDrivenAccessor();
                rebarShapeDrivenAccessor.SetLayoutAsFixedNumber(10, UnitUtils.ConvertToInternalUnits(1800, DisplayUnitType.DUT_MILLIMETERS), true, true, true);
                createRebar.Commit();
            #endregion
Error Images
@jeremytammik @naveen.kumar.t
jeremy_tammik
I seem to remember this being discussed here in the past couple of months... I think you can find the answer by searching for "rebar cover". Good luck!
arshad.k
Dear Jeremy Tammik
I searched, But I can't found what exactly I need. Can you guide me how to solve this...
@jeremy_tammik
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @arshad.k ,
I tested the sample code you attached.
I'm not getting any such errors.
I used this sample code
Rebar bar = Rebar.CreateFromRebarShape(doc, rebarShape, rebarType, hostElement, planeF.Origin, new XYZ(1,0,0), new XYZ(0,1,0));
Which Revit version are you using?
Could you please send us a small non-confidential reproducible sample code(I think we already have the sample code) and a simple non-confidential Revit model(rvt file) to recreate the issue?
Also, send us the detailed step-by-step instructions for reproducing the issue(i.e)which plane to choose
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremy_tammik
Please refer to the thread on constraining stirrups to the cover of the host element for a complete answer:
https://forums.autodesk.com/t5/revit-api-forum/problem-with-constraining-stirrups-to-the-cover-of-th...
