Rebar dimensions witness
Hi all,
For the rebar creation, I'm putting a dimension line, and the witness line is created like the image below. Is there a way to adjust the direction of this element and the length and position?
A similar thread has been discussed in the forum, but there is no answer yet. If you could help me with this, it would be a very big help for my development team.
I'll be attent to your response.
Best regards
jeremytammik
Dear Jorge,
Thank you for your query.
I do not see the image you refer to. Can you reattach it, please?
However, I see the images in the other thread that you mention.
Sorry to see that the previous issue has not been resolved yet.
Apparently, the development team did not answer my request that time around.
I'll give it another go.
I see from your reply to the other case that you can indeed achieve the desired adjustment manually in the user interface.
Thank you for confirming that.
I'll let you know as soon as I hear back from the development team.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks @jeremytammik. I'll be very attent to your response.
Here is the image I'm refering:
Regards
jeremytammik
Dear Jorge,
Thank you for your update and the screen snapshot.
Yes, I am attentive too 🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
