Rebar Creation with rebar shape
pyaezone
pyaezone
I want to get al l the RebarShape Types in the project and use one of them to create rebar using Rebar.CreateFromRebarShape.
I could get all rebar shape as elements using filteredElementCollector with BuiltInCategory.OST_RebarShape.
However, I cannot cast this element into RebarShape and as a result it is always null and cannot create using CreateFromRebarShape.
Is there any way I can achieve that?
jeremy_tammik
As a first step, I would suggest searching the Revit SDK samples for CreateFromRebarShape. I see it in the NewRebar and MultiplanarRebar samples. You should always perform two steps whenever you encounter a question like this:
