Reading parameter values in linked elements
Hi.
I'm working in Rvt2014, and i'm trying to get some parameter values from elements in linked models.
I can get the element, and read the parameter values, but for some reason I can't retrieve the values in some of them, (Mark, Comments, Type mark...) even when they exists...(instance and type parameters)
Here is my code for testing propose:
Public Sub t1()
        Dim ref As Reference
        Dim elem2 As Element
        Dim elem As Element
        Dim proyecto As String
        Dim elem3 As Element
         ref = ActiveUIDocument .Selection.PickObject(ObjectType.LinkedElement, "Seleccione tuberia, conducto o bandeja")
        elem2 = ActiveUIDocument .Document .GetElement(ref.ElementId) 'documento que contiene el elemento
             For Each docs As Document In Application.Documents 'busco el archivo linkeado
                 If docs.IsLinked Then
                     If InStr(elem2.Name, docs.Title) Then
                         elem = docs.GetElement(ref.LinkedElementId) 'ele elemento,
                          elem3=docs.GetElement (elem.GetTypeId )
                         proyecto = docs.Title
             Next
             Dim mensaje As String
             Dim parametros As ParameterSet
             parametros=elem.Parameters
             For Each p As Parameter In parametros
                 mensaje=mensaje  & p.Definition.Name & ": " & p.AsValueString    & vbCr
             Next
             TaskDialog .Show ("INFO",mensaje)
     End Sub
Can someone help me please?
Thankyou
Ups, I realized that .AsString works fine... I make a mistake when tested it for the first time...
