Re-Host a Face Based FamilyInstance
s_dineshkumarDEDFU
s_dineshkumarDEDFU
I have a Face Hosted family instance, if i delete the Host parent Element, the face based family instance got <not associated>, am trying to rehost to new host element face reference, is there any api to do that in revit, and i am
using to create face family instance by
doc.Create.NewFamilyInstance(refPlanarFace, origin, handDirection, famSymb)
jeremy_tammik
Afaik, the family instance HostFace property is read-only, and there are probably good reasons for that:
I afraid you will have to create a new family instance to place it on a different face.
Can you achieve what you want manually in the UI? How does that go? And how does it affect the database when you look at it through RevitLookup and other db exploration tools?
s_dineshkumarDEDFU
Hi @jeremy_tammik
Thanks for the reply
No, Manually it is not possible to rehost with new face, but manually we can copy or cut paste, by using this it will generate new face family instance, i really need to avoid the new family instance here and reuse the exisiting face family instance to be rehosted to newface
  • As i work with DB and revit look up i got the below information, the face family instance lose the information in sketchplane, but still the sketchplane is not deleted
