Re-Associating Model Groups
b.bloch58WMF
b.bloch58WMF
I have a tool that updates a family instance to a different family symbol.  I've recently run into an issue when I attempt to do this on a family that is in a model group.  By the following suggestions in the following post:
https://forums.autodesk.com/t5/revit-api-forum/how-do-i-go-into-group-edit-mode-with-the-api-amp-the...
I'm able to ungroup the the model group, make my change and then regroup it.  The problem, as the link suggests, is the associations are then lost between all of the instances of that model group.  I'm trying to wrap my head around a means to then go back through the new model groups that have been created and if any of them are exactly the same, replace the duplicates with a common group type so in effect they are associated back together.   So my question is, what would be the most efficient way to compare the model groups to find duplicates?
RPTHOMAS108
Before you ungroup wouldn't you record the other groups i.e.
1) Pick a group
2) Get it's group type
3) Record IDs of all other groups of that type (GroupType.Groups)
4) Look for instance parameters of elements within group with Definition.VariesAccrossGroups
5) Record parameter values for all parameters from (4). Each value of each parameter for each element within each group instance (Mapping of ElementID, ParameterID, Value/GlobalParameter).
6) Ungroup (1)
7) Make New Group
8] Change TypeId of all the other group instances of group from (3) to new group type (7)
9) For each element instance in each group correct the parameter values recorded in (5). These parameter values can be edited outside the group directly due to the nature of VariesAccrossGroups.
This above is for non-nested groups and you'll likely also lose dimensional references and visibility graphics overrides. Probably for nesting you need to record the form of nesting and fully ungroup so you can put it back together. Changing the parameter values for such is not anymore complicated bceuase you can record the items in a flat list (nesting likely makes no difference to the changing back of parameter values).
b.bloch58WMF
Thanks for the reply.
I was attempting to not get too much into the weeds of the entire tool but the data is being loaded from an external file to know which instances it needs to update.  When an item in a group is changed in Revit, it doesn't necessarily mean that all instances of the group will have the same reflected change in the external file.  That is why I was hoping to determine if the newly created groups were the same after the changes were made.
Now, having said that, I'm thinking maybe I need to do more upfront work to determine if the scenario I just described is present.  If it isn't, I can do just as you suggested.  If it is present, I could let the oddball groups become disassociated from the group type.  I need to wrap my head around that a bit.
Thank you!
RPTHOMAS108
Where it gets more complicated is when a group is nested in two different group types. If the nested group also existed on it's own as an instance outside the group then that would be fine you just update it in the same way. It seems also that the group type of a nested group can be changed from outside of the group (so that helps).
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
