RaaS issue cloud rendering
Message 1 of 1
Hello everyone,
I am hoping someone else got the same issue as me and will be able to help with. I would appreciate any suggestions or solution to the issue.
I have created a dynamo script where I render illuminance into the cloud render utilizing the cloud render node however it gives me the following error: Warning: CloudRendering.Run operation failed.
Could not load type 'Autodesk.RaaS.RevitAddin.Attribute' from assembly 'RaaSApplication, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null
Does someone know where I am able to Revit the file stated above? and where shall I place it to enable the cloud render to work successfully.
Kindest regards,
Giada
Replies (0)
