If I already have a list of Families and I want to iterate through all the familyinstances, what is the quickest way to get a a list in a collector.
so for each family...I iterate and call a method with this filtered element collector, which is very slow on a large project. Should i get the family symbols first for each family and use a where(family symbol has name...)
Also could i send the category first to reduce the time, I will check these myself I was just wondering if their are any major flaws in my approach?
foreach
FamilyInstance fi in new FilteredElementCollector(_doc)
.OfClass(typeof(FamilyInstance))
.WhereElementIsNotElementType()
.WhereElementIsViewIndependent()
.Cast<FamilyInstance>()
.Where(f => f.HasPhases() == true)
.Where(f => f.Name == _family.Name)
//do something with family instances
Solved by jeremytammik. Go to Solution.
That is an interesting question.
If you really want optimal speed in a large project with many instances, you will have to convert your LINQ Where<> clauses into something that can be run inside Revit by the filtered element collector itself.
As your code stands now, you are retrieving all data of all family instances and post-processing the result with Where<>.
If you eliminate the data retrieval and marshalling across from internal Revit memory to external add-in .NET memory, you will increase performance by at least 50 percent and maybe much more, cf.
http://thebuildingcoder.typepad.com/blog/2015/12/quick-slow-and-linq-element-filtering.html
Normally, the best alternative to the post-processing is to implement one or more parameter filters.
In this case, you could:
Et voila. That should provide the optimal solution.
Look here for further info:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
Please benchmark the solution you have right now.
Then, implement the suggestion above, benchmark that as well, and share your code and results.
That would be very nice of you!
Thank you!
Cheers,
Jeremy
Thanx for your advice Jeremy
I have modified my code to use the parameterFilters in 3 different methods that each use one or more collectors for filtered elements, I found how to do this one of your posts on parameter filters very nice post, personally I find them ugly to look at however that is not what it's all about. So I will in the future apply a timer, If I log some data do you want to see the difference between each method or just the overall time to completion of say a button event?
Dear Phil,
Both, please, if it is not too much bother.
Looking forward to seeing the results and a sample code snippet.
Thank you!
Cheers,
Jeremy
