Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Question? Updated RVT to NWC Export? (Automated)
Does anyone know if there is a way to use a Dynamo script and apply to all RVTs in a folder, to export them all as Navisworks NWC’s? (see attached visual for more information)
My question is specifically focused on step 2 of this process I am trying to automate, and how Dynamo could help me achieve this?
My first thought was to use Dynamo to achieve this, but if anyone knows of a better way to resolve this process I am certainly open to hearing it.
jeremytammik
Yes, you can automate exporting the Revit RVT to Navisworks.
The Revit API provides the Doucment.Export overload taking a NavisworksExportOptions argument for this purpose:
https://www.revitapidocs.com/2017/1b9538a9-a76b-0a40-2aed-e02f6974a43a.htm
In a Revit add-in, you can use the OS functionality to access all RVT files in the folder, open, export and close each in turn.
This functionality can also be made available in a Dynamo node.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
