Question on Revit requieremrnw
Hello.. I am a civil engineering student and want to buy a new computer to run the Autocad and Revit products.
Is the following machine with the following features good enough to run the applications smoothly?
ACER NITRO 5 GAMING NB,INTEL CORE i5-8300H/8GB/1TB/HDD GeForceGTX1050 4GB video.
Thank you.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
This link will help you to understand the Revit requirements
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks.. Ive already taken a view on that window with requirements, but
it's too vague in the CPU and Video Card required specs.. That's why I
don't knowif the system will run properly in a computer with the following
capabilities :
video dedicated
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
I hope this clarifies.
Naveen Kumar T
leowarren34
Hi @Anonymous,
From a general CAD perspective 8GB won't last you too long unless your models are very small. An SSD is also a recommendation these days. Puget have done a rough guide and some testing on this: https://www.pugetsystems.com/recommended/Recommended-Systems-for-Autodesk-Revit-171/Hardware-Recomme...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Thanks so much Leo! Your response makes sense to me.
leowarren34
Anytime, Glad I could help!
Leo Warren
