Question for Matching AnalyticalMember and FamilyInstance
powerstrong
powerstrong
I want to know some AnalyticalMember's properties. (for example, YZ_JUSTIFICATION)
I found that these properties are in FamilyInstance's parameters, by using RevitLookUp
Thank you Naveen and Jeremy 🙂
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-yz-justification-in-revit-api-2023/m-p/113...
I can get list of AnalyticalMember by this :
AnalyticalModels = new FilteredElementCollector(RvtDoc).OfClass(typeof(AnalyticalElement)).ToElements();
And list of FamilyInstance by this :
var elements = new FilteredElementCollector(revitDoc)
 .OfClass(typeof(FamilyInstance))
 .WhereElementIsNotElementType()
 .Cast<FamilyInstance>()
 .ToList();
Now I want to get FamilyInstance from AnalyticalMember(AnalyticalElement).
I spent several hours to find relation with two data, but don't know.
Can anyone help me?
RPTHOMAS108
In 2023 if the element has been given an association via:
AnalyticalToPhysicalAssociationManager.AddAssociation
Then it can be found via:
AnalyticalToPhysicalAssociationManager.GetAssociatedElementId
I believe this method works both ways i.e. on both the analytical or the physical as the parameter.
powerstrong
@RPTHOMAS108
OMG!
You solved the problem. Thank you so much 😁
