Python, door.Symbol.LookupParameter
s.hofer6LSK7
s.hofer6LSK7
Hey Guys,
i am a beginner in Pythonshell, i found the introduction on GitHub for the doors, but the "door.Symbol.LookupParameter("Type Name").AsString()) does not work. The letters do not appears in Bolt type.
I work with Revit 2022. Do you have any idea what is wrong?
Best regards
architect.bim
Hi!
Actually I do not quite understand what your problem is. But in case of "Type Name" parameter I suggest using BuiltInParameter enumeration instead of parameter name to avoid problems with Revit localization:
>>> door.Symbol.Parameter[BuiltInParameter.ALL_MODEL_TYPE_NAME].AsString()
'0915 x 2134mm'
P.S. don't forget to import BuiltInParameter before using it in the code.
from Autodesk.Revit.DB import BuiltInParameter
Maxim Stepannikov | Architect, BIM Manager, Instructor
s.hofer6LSK7
thanks a lot, with the "BuiltInParameter.ALL_MODEL_TYPE_NAME" it is works exactly how i want it. Best regards
