Purge Unused Images
Purge Unused Images
SONA-ARCHITECTURE
Message 1 of 10
Purge Unused Images
SONA-ARCHITECTURE
I can't correctly purge unsed images.
I'd like to got the same result as the tool called "Manage Images"
When I want to purge, for example  : TextNotes, I can use this method (founded in BuildingCoder thx) :
I collect all TextNotes type
I collect all TextNote instances, and for each instance I remove the ID of the Type in my Collection of TextNotes Type.
FilteredElementCollector collector = new FilteredElementCollector(BIM_Extracteur._doc);
//all textNotesTypes
ICollection<ElementId> textNotesTypes = collector.OfClass(typeof(TextNoteType)).ToElementIds().ToList();
//all TextNotes Instances
FilteredElementCollector textNotes = new FilteredElementCollector(BIM_Extracteur._doc).OfClass(typeof(TextNote));
foreach( TextNote textNote in textNotes )
bool removed = textNotesTypes.Remove(textNote.TextNoteType.Id);
But, with Images, it is more difficult and strange look :
For imagesType, it works fine  :the command is  :
ICollection<ElementId> ImagesTypes = collector.OfClass(typeof(ImageType)).ToElementIds().ToList();
But, for Images Instance, there is no Image type because image instance is typeof Element.
If I use this :
FilteredElementCollector ImagesCollector = new FilteredElementCollector(BIM_Extracteur._doc);
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_RasterImages);
ICollection<Element> images= collector.WherePasses(filter).ToElements();
The result is ImageType only
and when I use this :
ICollection<Element> images = new FilteredElementCollector(BIM_Extracteur._doc).OfCategory(BuiltInCategory.OST_RasterImages).ToElements();
Result is ImageType and Element for OST_RasterImage why?
And, if I got an image also used in Image parameter of my objets, that mean, I have to make a new filter to get all elements in all categories where image parameter containing my ImageType id?
Not sure to be very clear......sorry
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
Replies (9)
Message 2 of 10
Yien_Chao
Pierre,
for image instance did you try to add the filter : .WhereElementIsNotElementType() ?
that will catch only the instances.
hope it will help
Message 3 of 10
jeremytammik
Thank you, Yien, for the very relevant hint.
Just what I also wanted to suggest.
The Building Coder has discussed a number of aspects of purging different group of elements.
A summary is provided here:
Two more discussions have been added since then:
I really should summarise these all in an own dedicated topic group.
Since then, yet a few more related discussion include:
Oliver Green ported the VB code using the performance advisor to IronPython in case anyone fancies a copy:
Mike Turpin @ThatBIMthing added:
Got excited when i saw your post that there was a new solution then realised it was what i was already using 😁. I used this in my purge node in “turtle” dynamo package.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 4 of 10
SONA-ARCHITECTURE
Hi
Thx Jeremy for all those links.
Thx Yien
So, I can get all Image Instances.
WhereElementIsNotElementType().
I'm asking how Revit do for getting this kind ok list ?
'Cose I've got Generic models with Image property type added in those object.
I assume I have to use filter for all elements wich have an Image type parameter....
Pierre NAVARRA
SONA-Architecture.
Message 5 of 10
SONA-ARCHITECTURE
I thought make a Document.Delete and counting elements deleted in a ICollection<Autodesk.Revit.DB.ElementId> deletedIdSet but no way...
Pierre NAVARRA
SONA-Architecture.
Message 6 of 10
jeremytammik
Dear Pierre,
I do not understand exactly what you are trying to achieve, nor what problems you are encountering.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 10
SONA-ARCHITECTURE
Jeremy
Sorry Jeremy for not being clear enough ..
In fact, I would like to know if an image is not used (as an image stuck on a view or as an image assigned to a parameter I hope it's clearer now.
Pierre NAVARRA
SONA-Architecture.
Message 8 of 10
jeremytammik
Yes, that much is clear.
A number of different approaches and attempts to resolve very similar questions have been presented and discussed in the links listed above.
I am not clear on which of those you have tested, why they fail for you, and if so, how.
It might clarify things if you share a minimal reproducible case:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Jeremy Tammik
The Building Coder
Message 9 of 10
SONA-ARCHITECTURE
Thx Jeremy
I'm going to explorer solutions and I'll give you a feedback.
Many thanks for your disponibility
Pierre NAVARRA
SONA-Architecture.
Message 10 of 10
scott.deascentis
Observer
Observer
I'm so curious... what are you doing in this screenshot?  I love legos!
