Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Propagate Rebar using Revit API
1 REPLY 1
d6222300060
191 Views, 1 Reply
I would like to know if there is any function or method to utilize the propagate rebar functionality added in Revit 2023 and Revit 2024 using Revit API. I have searched the Revit API docs but I haven't found it.
Tags (2)
Labels (3)
1 REPLY 1
Hi @d6222300060 ,
Are you perhaps looking for RebarPropagation class that is on the link below?
https://www.revitapidocs.com/2024/c3d2d1ea-47e5-12d6-40a9-25fa3cf15fb7.htm
You can also use Revit Lookup tool which will give you a lot more information on the same.
  Moturi George,     Developer Advocacy and Support,  ADN Open
Forma Design Contest
Rail Community
