Project Parameters
Project Parameters
Project Parameters
I am trying to write something that will get the categories that a certain project parameter is assigned to, and can't seem to find where in Revit API that you can access that info. I found in the help how to set new shared parameters, but that didn't seem to help. Thanks
Try looking in the Revit 2011 SDK (download from Autodesk if you haven't already)
The sample that should demonstrate what you're after is: ..\Revit SDK 2011\Samples\BrowseBindings
You can translate to C# here:
http://www.developerfusion.com/tools/convert/vb-to-csharp/
Or try poking around in Jeremy's example that is similar:
http://thebuildingcoder.typepad.com/blog/2009/09/adding-a-category-to-a-parameter-binding.html
-Don
