project informations parameters values
i read the project information parameters using binding method but not able to read the values please help me regarding this.
augusto.goncalves
If I understood your question, this project information should be under Document.ProjectInfo, look at the properties.
You mention "binding", are you referring to WPF binding? If so, are you binding against AsValueString property of the parameter?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hello Augusto,
Instead of Binding i passed the document to element and loop this element as a parameter.
But thanks for your reply.
