Programmatically display custom families in property palette to allow user to choose and create an instance
jay.lei
jay.lei
Hi, I would like to know if it is possible to programmatically display some of my own custom families in the "property" palette to allow the user to choose a family and place an instance in the document.  I already learned how to programmatically load families into the document, but I would like to display them in the property palette to allow the user to choose.  Just like what the "Mechanical Equipment" button in the "System" ribbon does.  The only difference is that I would like to display my own families in the "property palette", not mechanical equipment.
I'm grateful for any help here.
jeremy_tammik
The built-in Revit property palette only displays Revit element properties, afaik. I don't think you have any direct programmatic access to the palette itself. You could implement your own modeless floating family selection palette, though. Such a task was discussed right here just yesterday:
https://forums.autodesk.com/t5/revit-api-forum/user-defined-family-palette/td-p/11373330
mhannonQ65N2
I did a quick test with placing a family by calling PostRequestForElementTypePlacement and found that I could edit the instance's properties before placing it. So you don't need to do anything specific to make Revit use the properties pallet.
jay.lei
Thanks a lot!  I will try this method.
