Problems using InstanceVoidCutUtils.GetElementsBeingCut
dsmith
dsmith
Hi
I have a wall panel that is being cut by another family, everything is good
When I try to check that the panel is actually being cut by the family
 using InstanceVoidCutUtils.GetElementsBeingCut('Cutting Instance') then it always returns a zero count.
I have spent most of the day on this an soon the computer is going out of the window
Thanks in Advace
Dave
RPTHOMAS108
Do you have a sample file plus code for this? Sounds like something that could be easily reproduced and a case of something in the API not doing what it says it should (if it is being cut).
