Problems to install Revit
Good evening.
I am a student of the building construction course and need to learn how to use Revit. I have tried to download all the versions available on the site but it always gives an error when installing the program. There is some information about this failure. It always ends the installation process after spending hours downloading and installing it and says that it was not possible to install the software and library.
Thank you and I await your return.
Veronica
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
What's the exact error message you encountered? Please disable your firewall and anti-virus programs, and re-download the software from our Virtual Agent (click on Download Links, choose product and version). Then try the installation again.
Lynn Zhang
jeremytammik
Dear Veronica, dear Lynn,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
