Problem with transaction
cugelkater
cugelkater
When Im run this script there is error:
"No transaction attribute.
Could not run the add-in because it does not have the Transaction attribute assigned."
What is missing here? Maybe it is related to the .addin file?
using System;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
namespace lib1
    public class SelPW_save
        public static ICollection<ElementId> SavedElementIds { get; set; } = new List<ElementId>();
    [Transaction(TransactionMode.Manual)]
    public class SelPWget1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            Document doc = uiDoc.Document;
            // Transaction begin
            using (Transaction trans = new Transaction(doc, "trans"))
                trans.Start();
                try
                    ICollection<ElementId> selectedIds = uiDoc.Selection.GetElementIds();
                    if (selectedIds.Count == 0)
                        TaskDialog.Show("Info", "No elements has been choosen");
                        return Result.Succeeded;
                    SelPW_save.SavedElementIds = selectedIds;
                    string idList = "Element IDs:\n";
                    foreach (ElementId id in selectedIds)
                        idList += id.IntegerValue + "\n";
                    TaskDialog.Show("Result", idList);
                    trans.Commit();
                catch (Exception ex)
                    trans.RollBack();
                    TaskDialog.Show("error", ex.Message);
                    return Result.Failed;
jeremy_tammik
Hard to tell without seeing the add-in manifest file. It needs to specify your full class name, lib1.SelPWget1. Just follow the instructions in the add-in integration guide and all will be well:
