Problem with graphic on UHD screen
I'm Revit, Robot and AutoCAD user. Couple of weeks ago I bought new laptop Samsung Notebook 9 with UHD screen with resolution 3840x2160 pix. I installed all of my Autodesk programs and here is some problem - I attached some screenshots to this post. All of the icons are too small, so it's hard to even see what is on screen right now. Moreover, in settings some lists are unable to use. I have to say that I've already installed all of the updates for graphic cards.
Does anyone have problem like me and could help with solving this inconvenience?
Thanks for help! 🙂
Upgrade to Revit 2017.1 which will fix this issue.
Regards
Phillip
It doesn't help in my case and what's more the same things happen in
AutoCAD and Robot, especially if we talk about result list (Revit), Load
list (Robot) or even simply properties in AutoCAD.
Ok, it works with 2017.1. Autodesk App didn't find this update, so I thought I've got the latest one. Same thing for AutoCAD, 2017.1 solves all of the issues.
I've got still some problems with Robot, because SP1 didn't make any difference. It looks almost the same, small icons and really bad resolution of the list so I can't use them at all 😞 Any suggestion what to do with this program?
I saw exactly the same issue as you until I upgraded to Revit 2017.1.  Now it has been fixed as per my screen capture. 🙂2016-10-20_11-11-33.png
Any ideas what to do if upgrade Revit to 2017.1 didn't change anything in
Robot?
