Problem with Civil 3D generated toposurfaces from TIN surfaces
Hi!
 I've been working on an add-in that will let you pick tin surfaces from an open Civil 3D-model and then create toposurfaces of those in Revit. The problem I have is when I pick two tin surfaces at a time, Revit creates one toposurface of the first tin surface I picked and another toposurface conisting of both tin surfaces. My goal is to create two separate toposurfaces. I can't figure out where I've messed up, can someone help me? I'll attatch a screencast and my code.
    public partial class Import_form : System.Windows.Forms.Form
        public IAeccSurfaces surfs;
        public List<List<XYZ>> topos = new List<List<XYZ>>();
        private Autodesk.AutoCAD.Interop.IAcadApplication m_oAcadApp = null;
        private Autodesk.AECC.Interop.UiLand.IAeccApplication m_oAeccApp = null;
        private Autodesk.AECC.Interop.UiLand.IAeccDocument m_oAeccDoc = null;
        private IAeccDocuments m_oAeccDocs = null;
        private Autodesk.AECC.Interop.Land.IAeccDatabase m_oAeccDb = null;
        string m_sAcadProdID = "AutoCAD.Application";
        string m_sAeccAppProgId = "AeccXUiLand.AeccApplication.13.0";
        double[] triangles;
        List<double> nummer = new List<double>();
        public Import_form()
            InitializeComponent();
            m_oAcadApp = (IAcadApplication)Marshal.GetActiveObject(m_sAcadProdID);
            if (m_oAcadApp != null)
                m_oAeccApp = (Autodesk.AECC.Interop.UiLand.IAeccApplication)m_oAcadApp.GetInterfaceObject(m_sAeccAppProgId);
                m_oAeccDoc = (Autodesk.AECC.Interop.UiLand.IAeccDocument)m_oAeccApp.ActiveDocument;
                m_oAeccDocs = (Autodesk.AECC.Interop.UiLand.IAeccDocuments)m_oAeccApp.Documents;
                m_oAeccDb = (Autodesk.AECC.Interop.Land.IAeccDatabase)m_oAeccApp.ActiveDocument.Database;
                comboBox1.Items.Add(m_oAeccDoc);
                comboBox1.SelectedIndex = 0;
                comboBox1.DisplayMember = "Name";
                comboBox1.SelectedItem = m_oAeccDoc;
                surfs = m_oAeccDb.Surfaces;
                foreach (IAeccTinSurface surf in surfs)
                    checkedListBox1.Items.Add(surf);
                ((ListBox)checkedListBox1).DisplayMember = "Name";
        private void Import_form_Load(object sender, EventArgs e)
        private void button1_Click_1(object sender, EventArgs e)
            /*int antal = tjo.Count();
            MessageBox.Show(antal.ToString());*/
        public static List<List<double>> splitlist(List<double> nummer, int antal = 3)
            var list = new List<List<double>>();
            for (int i = 0; i < nummer.Count; i += antal)
                list.Add(nummer.GetRange(i, Math.Min(antal, nummer.Count - i)));
            return list;
        private void checkedListBox1_Click(object sender, EventArgs e)
        private void button2_Click(object sender, EventArgs e)
            foreach (IAeccTinSurface valdsurface in checkedListBox1.CheckedItems)
                triangles = valdsurface.OutputTriangles;
                List<XYZ> punkter = new List<XYZ>();
                List<XYZ> utpunkter = new List<XYZ>();
                double x = 0, y = 0, z = 0;
                foreach (double d in triangles)
                    nummer.Add(d);
                List<List<double>> uppdelning = splitlist(nummer, 3);
                foreach (List<double> uppdelat in uppdelning)
                    for (int k = 0; k < uppdelat.Count; ++k)
                        int j = 1;
                        foreach (double d in uppdelat)
                            switch (j)
                                case 1:
                                    x = d;
                                    break;
                                case 2:
                                    y = d;
                                    break;
                                case 3:
                                    z = d;
                                    break;
                                default:
                                    break;
                            j++;
                        punkter.Add(new XYZ(x, y, z));
                topos.Add(punkter);
 public class Civil_import : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
            Autodesk.Revit.Creation.Application appcrea = uiapp.Application.Create;
            Autodesk.Revit.DB.Document doc = uiapp.ActiveUIDocument.Document;
            Autodesk.Revit.DB.View currentview = uiapp.ActiveUIDocument.ActiveView;
            List<List<XYZ>> lists_out = new List<List<XYZ>>();
            Import_form f = new Import_form();
             var result = f.ShowDialog();
             if(result==DialogResult.OK)
                using (Transaction t = new Transaction(doc))
                    t.Start("ett");
                    foreach (List<XYZ> punkter in f.topos)
                        List<XYZ> ut = new List<XYZ>();
                        GetVertices(ut, punkter);
                        lists_out.Add(ut);
                    foreach(List<XYZ> tops in lists_out)
                        TopographySurface.Create(doc, tops);
                    t.Commit();
             if (result==DialogResult.Cancel)
                 return Result.Cancelled;
            return Result.Succeeded;
        const double _eps = 1.0e-9;
        public static bool IsZero(double a)
            return _eps > Math.Abs(a);
        public static bool IsEqual(double a, double b)
            return IsZero(b - a);
        public static int Compare(double a, double b)
            return IsEqual(a, b) ? 0 : (a < b ? -1 : 1);
        public static int Compare(XYZ p, XYZ q)
            int diff = Compare(p.X, q.X);
            if (0 == diff)
                diff = Compare(p.Y, q.Y);
                if (0 == diff)
                    diff = Compare(p.Z, q.Z);
            return diff;
        static void GetVertices(List<XYZ> listut, List<XYZ> listin)
            Dictionary<XYZ, int> a
              = new Dictionary<XYZ, int>(
                new XyzComparer());
            foreach (XYZ p in listin)
                if (!a.ContainsKey(p))
                    a.Add(p, 1);
                else
                    ++a[p];
            List<XYZ> keys = new List<XYZ>(a.Keys);
            keys.Sort(Compare);
            foreach (XYZ p in keys)
                listut.Add(p);
    public class XyzComparer : IEqualityComparer<XYZ>
        public bool Equals(XYZ p, XYZ q)
            return p.IsAlmostEqualTo(q);
        public int GetHashCode(XYZ p)
            return p.ToString().GetHashCode();
jeremytammik
It sounds to me as if your selection process is adding things to a list, and you are not clearing the list after processing it.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks for the quick reply!
I think I have an Idea where to look.
Btw, kudos to your blog, I've learned a lot!
Revitalizer
please note that there are two methods to create a TopographySurface (Revit 2020 API).
If you have edges that you want to preserve, you better use
TopographySurface Create(
	Document document,
	IList<XYZ> points,
	IList<PolymeshFacet> facets
instead of
	Document document,
	IList<XYZ> points
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
