Problem when mirroring newly modified family instance
My situation is this:
  • A new family instance is placed
  • some instance parameters in the new family instance is modified
  • the family instance is mirrored
  • the mirrored instance don't inherit the newly modified parameters
Here's my code:
FamilyInstance instance = doc.Create.NewFamilyInstance(somePoint, someSymbol, Autodesk.Revit.DB.Structure.StructuralType.NonStructural);
ElementTransformUtils.RotateElement(doc, instance.Id, someLine, someRotation);
instance.LookupParameter("Width").Set(someWidth);
instance.LookupParameter("Height").Set(someHeight);
instance.LookupParameter("Depth").Set(someDepth);
ElementTransformUtils.MirrorElement(doc, instance.Id, somePlane);
The weird thing is that if I run the MirrorElement() function twice, it will work the second time! I thought because of this that the first mirror function ran before the parameters were successfully modified, but I've tried different delay tricks, but with no luck.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
Does rotating the element in a transaction and mirroring the rotated element in
a second transaction(as below code snippet) solve your issue ?
1.Start the transaction
Transaction Rotate_element = new Transaction(doc);
 Rotate_element.Start("Rotating Element");
2.Rotate the element
3.Get the  of rotated element.
FilteredElementCollector Element_collector = new FilteredElementCollector(doc).OfClass(typeof(FamilyInstance)).WhereElementIsNotElementType();
                IList<Element> elementss = Element_collector.ToElements() as IList<Element>;
                FamilyInstance Fam_inst = null; ;
                int i = Element_collector.Max<Element>(y => y.Id.IntegerValue);
                ElementId MAX_ID = new ElementId(i);
                foreach(Element e in elementss)
                    if(e.Id==MAX_ID)
                        Fam_inst = doc.GetElement(e.Id) as FamilyInstance;
                        break;
4.Commit the transaction
Rotate_element.Commit();
5.Open  a New transaction
Transaction Mirror_transaction = new Transaction(doc);
 Mirror_transaction.Start("Mirror");
6.Mirror the element
 Element rotated_element = Fam_inst as Element;
ElementId rotated_element_id = rotated_element as ElementId;
ElementTransformUtils.MirrorElement(doc,rotated_element_id, plane);
7.commit the second transaction
Mirror_transaction.Commit();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
frankholidayjunior
Does anyone know of way to get a mirrored instances mirrored plane, so that I can replicate this when creating a familyInstance that is identical?
frankholidayjunior
I would probably do something like this...
get the flip plane
FlipElement(some plane etc in the method overload)
