Problem: Revit2020 UI keeps resetting after program restart
GertjanvandenbroekVKAE
For some reason, each time I start revit 2020 all of my settings are reset to default. Panels, windows, shortcuts, color settings.
This is extremely annoying.
Not sure this is the right place to ask though
jeremytammik
Yes, indeed, I am sorry to say this is not the right place to ask.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
