Problem of Setting LocationCurve of Pipes
1056716949
1056716949
I'm working on setting PipingSlope of Pipes by changing their locationcurve.
As the screenshots shown below,the parameter value won't show correctlly unless I move the pipe which has changed its locationcuve.
I think I can fix this by the method -- "ElementTransformUtils.MoveElement()",but it may cause some troubles when the pipe connected fittings or other equipments.
I just got the solution.
ElementTransformUtils.MoveElement(doc, mep.Id, XYZ.Zero);
