Problem in WindowsForm font
ywkimPXXW3
ywkimPXXW3
When I open project directly in folder, there is problem in WindowsForm's font.
However, if I open Revit and open or create a project, no problem occurs.
Revit 2022 / VisualStudio 2017 / Window 10
This is when open project directly in folder.
This is when open revit and load or create project.
The language is korean.
I try to find solution and I find similar question.
But there is no replies.
https://forums.autodesk.com/t5/revit-api-forum/windows-form-font/m-p/10415831
jeremy_tammik
You say there is a similarity with the other case you pointed out. I understand the other case, saying that the font appears differently in Revit 2021 and Revit 2022. I passed on the question to the development team to hear whether they have any advice on this.
Unfortunately, I am confused by the two variants you describe. I don't quite understand the differences between one and the other. Can you clarify, please? You say:
I don't know what that means.
I don't know what that means, either.
Are you also observing differences between different versions of Revit? If so, which versions?
If not, what is the similarity with the other thread?
ywkimPXXW3
-> This is the case of double-clicking the rvt file to open it.
(double click rvt file)
-> This is the case of opening the rvt file after executing revit.exe.
(double click revit.exe -> open rvt in revit)
And I'm only using the Revit 2022 version.
jeremy_tammik
Thank you for the clarification. Well, that sounds like a different issue to me. Similar result, completely different cause.
