Problem in exporting model in .dae format.
Message 1 of 10
When i try to export my 3d model in revit 2020 software it is giving me an error as 'object reference is not set to an instance of an object error'. Can you please help me with it?
Replies (9)
Message 2 of 10
jeremytammik
The information you share about the problem is insufficient. I don't think anybody can help you based on that short statement. Are you yourself the programmer of the exporter add-in?
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
I AM USING THE REVIT 2020 AND USING THE LUMION 6.I HVE AN ISSUE RELATED TO
EXPORT TO .dae. and i use the revit bridge from official website of
lumion. it show name)-description:object reference not set to an instance of an object.>i m
using a windows10.
so kindly lookout the issue or we can communicate through a anydesk
software.
Message 4 of 10
jeremytammik
The Lumion exporter is a product by Lumion, and they are the only ones that can help you with this:
https://support.lumion.com/hc/en-us/articles/360007538494-Download-Lumion-LiveSync-for-Revit
Kindly contact them for help on sorting this out.
Good luck and best regards.
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 10
sir thanking u for but i have one issue also is in ribbon of add in
revit2020 the external tool option isn't visible.so can u please help me
for solving this.full procedure or product info from where i can download
or repair the add in option of revit 2020.
Message 6 of 10
jeremytammik
It is probably a problem with your add-in registration.
Here is the documentation for that:
https://help.autodesk.com/view/RVT/2021/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
For further details, all the basic fundamentals and full tutorials on installing Revit add-ins, please refer to the Revit API getting started material:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Jeremy Tammik
The Building Coder
Message 7 of 10
sir sorry to say that its really don't work for export and add in>external
tool issue another way to resolve through any desk or other online mode due
to this u can properly understand the issue or u will resolve it thank u
for cooperating
Message 8 of 10
did you solve the refrence problem?????
Message 9 of 10
yes i find the solution
Message 10 of 10
jeremytammik
Congratulations. What was the exact problem? What is the solution?
Jeremy Tammik
The Building Coder
