Problem in creation of Detail Line
MehtaRajesh
MehtaRajesh
Hello All,
I am creating Detail Line in View, I am getting error "System.NullReferenceException: Object reference not set to an instance of an object"  at DetailLine line1 = doc.Create.NewDetailCurve(view, geomLine1) as DetailLine;
Please let me know why this error is coming and what is the solution,
Thanks in advance for your kind support in this regards
Rajesh
ExternalCommandData cdata = commandData; m_app = commandData.Application; m_doc = commandData.Application.ActiveUIDocument.Document; view = m_doc.ActiveView; uiApp = commandData.Application; uiDoc = uiApp.ActiveUIDocument; app = m_app.Application; if (null == m_doc) { message = "There is no active document."; return Autodesk.Revit.UI.Result.Failed; } // Create a few geometry lines. These lines are transaction (not in the model), // therefore they do not need to be created inside a document transaction. XYZ Point1 = XYZ.Zero; XYZ Point2 = new XYZ(10, 0, 0); XYZ Point3 = new XYZ(10, 10, 0); XYZ Point4 = new XYZ(0, 10, 0); Line geomLine1 = Line.CreateBound(Point1, Point2); // This geometry plane is also transaction and does not need a transaction XYZ origin = XYZ.Zero; XYZ normal = new XYZ(0, 0, 1); Plane geomPlane = app.Create.NewPlane(normal, origin); using (Transaction transaction = new Transaction(m_doc)) { if (transaction.Start("Create model curves") == TransactionStatus.Started) { // Create a sketch plane in current document SketchPlane sketch = SketchPlane.Create(m_doc, geomPlane); DetailLine line1 = doc.Create.NewDetailCurve(view, geomLine1) as DetailLine; (ERROR I am getting is System.NullReferenceException: Object reference not set to an instance of an object }
Hello MehtaRajesh,
are you running it in a view where detail lines can't be created?
Where do you start/Commit your transaction?
/Martin
MehtaRajesh
Hi Martin,
I need to create Detail Line in currently opened Sheet,
Please help me, what I am doing wrong in the code.
Thanks and Regards,
Rajesh
When creating your detail line you are using doc.create but your Document variable is named m_doc
Change your transaction to something like this:
Transaction transaction = new Transaction(m_doc, "Create Detail Line");
 transaction.Start();
      DetailLine line1 = m_doc.Create.NewDetailCurve(view, geomLine1) as DetailLine;
 transaction.Commit();
Good Luck!
 /Martin
