Problem importing identity data from IFC to Revit
Gustavo_Teixeira.cbm
Observer Observer
Observer
Observer
I received a project developed in Revit in the IFC format. The company had exported all the information, as I can read all the identity data using an IFC viewer, but when opening it in Revit, the project lost its information. Is there any configuration that I can use to solve this problem? Thank you!
jeremytammik
Dear Gustavo,
It sounds to me as if you are looking for an end user solution to this task and you are not doing any programming yourself using the Revit API.
In that case, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
