I'm working on a program to print and combine sheets in a company standardized order. For example Sheet numbers with MD should be before the M sheets in the combined pdf file.
Doing the research I am finding very little information about the printManager Class.
My questions are:
1. How do I set a property to true in the print manager? Such as printManager.CombinedFile property.
2. How do I set the printing setup to a saved setup created previously? (Click File>Print>Setup>Name:Dropdown)
Any help on this would be huge. I've got my SheetSet worked out to where I can print desired sheets, and I've printed them individually. I would like to combine them with the print setup so that they are the correct paper size.
Note:
I understand there are programs that somewhat do this. This is a company standard that I'm trying to follow and will be used many data collection processes for proposals.
Thanks!!
Kale Harper
