Printing to PDF using Bluebeam issue
I started using Revit 2020 about a month ago. Since switching to 20, I have had trouble printing drawings to PDF using Bluebeam. I'll hit print, select the sheets I want and change the settings as needed, and then hit ok. It will then pull up the 'save as' menu asking where I want to save the PDF's. I'll make the selection and hit save. The problem is, after allowing me to print 1 or 2 drawings, the save as menu stops coming up. The only way to print the remainder of the drawings is to start the printing process over. If I'm printing 10 drawings, I may have to attempt to print 5 or 6 times before it actually allows me to get through each drawing. Once I'm finally able to get every drawing printed, it will keep bringing up the save as menu (as I've now tried to print the 10 drawings 5-6 times). So, I have to sit there and hit cancel until it stops. This is an extremely frustrating issue as it is wasting a lot of my time every time I print.
Has anyone else had this issue? If so, how did you fix it?
