Printing Settings
Printing Settings
BrentBurgess1980
Printing Settings
BrentBurgess1980
Hi all,
When I use this code below, my printing is not producing any different output, even if I make changes to zoom, colour etc. Is there something I am missing or not setting properly?
    [Transaction(TransactionMode.Manual)]
    public class PrintSettingsCommand : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document OpenDoc = App.CurrentDocument;
            PrintManager printManager = OpenDoc.PrintManager;
            printManager.PrintSetup.CurrentPrintSetting = printManager.PrintSetup.InSession;
            printManager.SelectNewPrintDriver(App.BASPalette.cboPrinter.SelectedItem as string);
            printManager.PrintToFile = true;
            printManager.PrintRange = PrintRange.Select;
            printManager.PrintToFileName = string.Format(@"C:\PDF\{0}.pdf", OpenDoc.ProjectInformation.Name);
            IPrintSetting printSettings = printManager.PrintSetup.CurrentPrintSetting;
            ViewSheetSetting viewSheetSetting = printManager.ViewSheetSetting;
            ViewSet viewSet = new ViewSet();
            for (int i = 0; i < App.BASPalette.lvwSheets.SelectedItems.Count; i++)
                WSPSheet sheet = App.BASPalette.lvwSheets.SelectedItems[i] as WSPSheet;
                if (sheet != null)
                    if (sheet.View.CanBePrinted)
                        viewSet.Insert(sheet.View);
            printSettings.PrintParameters.PageOrientation = PageOrientationType.Landscape;
            printSettings.PrintParameters.PaperSize = App.BASPalette.cboPaperSize.SelectedItem as PaperSize;
            printSettings.PrintParameters.ZoomType = ZoomType.Zoom;
            printSettings.PrintParameters.Zoom = 100;
            printSettings.PrintParameters.ColorDepth = ColorDepthType.GrayScale;
            using (Transaction transaction = new Transaction(OpenDoc))
                transaction.Start("Set in-session views");
                viewSheetSetting.InSession.Views = viewSet;
                transaction.Commit();
            printManager.PrintSetup.CurrentPrintSetting = printSettings;
            printManager.CombinedFile = true;
            printManager.Apply();
            OpenDoc.Print(viewSet, true);
            return Result.Succeeded;
jeremytammik
Have you searched this forum for existing answers before raising your question?
Here is an issue that was successfully resolved that sounds pretty similar to yours:
https://forums.autodesk.com/t5/revit-api-forum/viewsheet-set-to-be-printed-setting-problem/m-p/88231...
Jeremy Tammik
Developer Technical Services
The Building Coder
BrentBurgess1980
BrentBurgess1980
I managed to take the viewprinter from the SDK and modify to suit my requirements.
luis7SJJ3
What was the solution?
