Print to PDF issue for printmanager Revit API
When I tried to use printManager API for Revit using C# for the batch process,
It is asking "Save as" dialog every time and expecting user has to click Ok. Can anyone help me to stop this dialog?
Kisli89
Hi, I use BulzipPDF, it allows you to configure settings via C#.
Also there are other settings, for example, you can set the path to a folder or merge files.
http://wiki.bullzip.com/pdf-printer/examples/printing-microsoft-word-documents-to-pdf-using-c
Thank you for the response. Is Bullzip a freeware?
-Vijay
Kisli89
Yes it freeware.
Thank you
Revitalizer
please note that this "Freeware" is not as free as you might think:
http://www.bullzip.com/products/pdf/info.php
"This program is FREEWARE with limitations, which means that there is a FREE version for personal and commercial use up to 10 users."
If you don't know the number of people using your add-in, you cannot use it at all, so you need to purchase a commercial licence.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
dantartaglia8696
There may be another way around your issue using the API but I currently: change my computer's Adobe PDF printing preferences like this: set 'Adobe PDF Output' to "Documents\*.pdf" and disable 'View Adobe PDF results'. It should resolve your issue but I haven't investigated using more of the API to resolve it in a long while.
HTH
