Preprocess schema conflict errors
I would like to hide all "Shema Conflict when Loading a File" messages and create a single message that gives a summary of all schema conflicts.
Currently I am unable to catch this error, because the error message is generated before the DocumentOpened event and I can't use Document.SetFailureHandlingOptions on the DocumentOpening event, because the Document is not generated yet here.
Is it possible to preprocess and hide the "Shema Conflict when Loading a File" messages and how can I do this?
Revitalizer
Hi kay,
I've posted an answer in a different thread:
https://forums.autodesk.com/t5/revit-api-forum/capture-warning-message-during-the-save-with-a-revit-...
"I would suggest to look at the ErrorHandling sample in the Revit SDK, at the Command.cs file.
There is a FailuresProcessing event with the Application class (and also with the ControlledApplication class).
That means, independent of your own Transactions, you can intercept the FailuresProcessing in a general context."
I don't know if this may help you solving your problem, but it's a starting point...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
It seems like Application.FailuresProcessing and ControlledApplication.FailureProcessing do not catch the schema conflict failure.
These events are called once inbetween opening a project and the scheme conflict popup message, but there are no failure messages(failuresAccessor.GetFailureMessages()) and the event is also called when a project is opened without any conflicting schema's.
FlorisvdG
Any update on this? I'm running into the same problem. Schema Conflict errors are not caught by the FailureProcessors..
