PostCommand
PostCommand
Message 1 of 15
PostCommand
I am using the following code:
RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.PlaceAComponent);
bool b = uiapp.CanPostCommand(commandId); // returns true
uiapp.PostCommand(commandId);
but it always places furbiture-desk. Can please anybody help me out in placing a group.
Thanks & Regards
Sanjay Pandey
Replies (14)
Message 2 of 15
Mustafa.Salaheldin
What do you want to do in first place?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 3 of 15
RevitArkitek
The API help says it will place based on a selected element type.  Try putting the GroupType into the UIDocument.Selection then call PostCommand
Message 4 of 15
I am trying to mimick group placement. Exactly the same way we place group manually
Thanks & Regards
Sanjay Pandey
Message 5 of 15
jeremytammik
You should probably not be trying to use PostCommand.
Take a look at PromptForFamilyInstancePlacement instead.
There are lots of discussions on it in The Building Coder.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 6 of 15
Thanks for your suggestion.
I tried your suggestion. I first placed the group and selected it and called the code:
ICollection<ElementId> eed = uidoc.Selection.GetElementIds();
uidoc.Selection.SetElementIds(eed);
RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.PlaceAComponent );
but it always places desk
Thanks & Regards
Sanjay Pandey
Message 7 of 15
PromptForFamilyInstancePlacement does not work for group placement.
Thanks & Regards
Sanjay Pandey
Message 8 of 15
on further exploration I found PostableCommand.PlaceAComponent only works for family instances
Thanks & Regards
Sanjay Pandey
Message 9 of 15
RevitArkitek
I said the GroupType not a group instance.  Get the element ID of the GroupType and place that in selection.  This is the same as if you were looking at the properties of a group or family from the Project Browser.  I do not know if it will still work or not though.
Message 10 of 15
Thanks for the support.But I am loosing hope now. I will depict the out come of the following code via screenshots:
 FilteredElementCollector collector = new FilteredElementCollector(Command.doc).OfClass((typeof(GroupType)));
           var groupTypes = from element in collector
                            where element.Name == "MICRO PAD OE 45"
                            select element;
           Element groupType = groupTypes.First();
           GroupType ty = (GroupType)groupType;
           ICollection<ElementId> eed = new Collection<ElementId>();
           eed.Add(ty.Id);
OUTCOME OF THE CODE:
AS I Told you this works only with family Instances only. Also I have no clue why it picked up the desk to place.
Thanks & Regards
Sanjay Pandey
Message 11 of 15
Mustafa.Salaheldin
Oh god don't you ever lose hope Smiley Very Happy
Here is the solution
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                FilteredElementCollector collector = new FilteredElementCollector(cmdData.Application.ActiveUIDocument.Document).OfClass((typeof(GroupType)));
                                 select element;
                cmdData.Application.ActiveUIDocument.PostRequestForElementTypePlacement (ty); //for revit 2015 and later
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
If this statisfies your needs, don't forget to mark this reply as an answer.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 12 of 15
WOW WOW WOW.
That worked like charm. Thanks a Ton.
Thanks & Regards
Sanjay pandey
Message 13 of 15
Mustafa.Salaheldin
Good to hear that.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 14 of 15
I have already accepted your solution(marked as answer) along with a Kudo.
Thanks once again.
Message 15 of 15
jacsmithstrongtie
@Mustafa.Salaheldin Do you have any experience working with the PostableCommand.MirrorProject Post Command?  Also does what you shared with @Anonymous work from clicking a button in the ribbon or does the command you wrote for him generated automatically?  Sorry I am a new developer, and I am trying see if I can automate the Mirror Project feature in Revit 2024.
