PostableCommand.RevisionCloud doesn't work
AnatolyCEL
AnatolyCEL
UIApplication uiApp
uiApp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.RevisionCloud)) doesn't work, but if I change it to:
uiApp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.DetailLine)), works fine
Thanks.
arnostlobel
In what version of Revit?
Arnošt Löbel
AnatolyCEL
2014, 2015 doesn't work at all. In 2016 works only from external command (start drawing after the external commad finished, which is good), but after return to Revit (PastCommand from modeless window) doesn't.
Aaron.Lu
Tried RevisionCloud in 2015 and 2016, both of them did not work. Should we log an issue for it?
Aaron Lu
Developer Technical Services
Autodesk Developer Network
AnatolyCEL
Yes, please
AnatolyCEL
The PostCommand doesn't work for FiledRegion too. I suspect that it affects all commands having Edit mode with red cross and green checkmark.
Aaron.Lu
Dear, I've got the message from dev team that the bug was fixed in the upgrade version of Revit, i.e. Revit 2016 SP2, you can do an update to see if it has been fixed.
Aaron Lu
