Possible bug? LinePatternElement.GetLinePattern returns null with a valid ElementId
thomas
thomas
I'm unable to return the LinePattern object from a GraphicStyle which has a valid line pattern Id. Using Revit 2022.
For example the built-in <Insulation Batting Lines> has a line pattern id associated as GetLinePatternId() returns the built in (negative) element id.
When I attempt to retrieve the LinePattern object via LinePatternElement.GetLinePattern(doc, linePatternId) it always returns null. The API documentation states that the linePatternId input can be "The ElementId of the LinePatternElement or the built-in line pattern id."
Here is a code snippet in Python to test (I'm doing a quick test in Dynamo):
import clr
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
clr.AddReference("RevitAPI")
import Autodesk
from Autodesk.Revit.DB import *
doc = DocumentManager.Instance.CurrentDBDocument
lineStyle = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines)
lineStyleSubTypes = lineStyle.SubCategories
lineStyleAttributesList = []
for category in lineStyleSubTypes:
	gs = category.GetGraphicsStyle(GraphicsStyleType.Projection)
	lineStyleAttributesList.Add(gs)
gs1 = lineStyleAttributesList[0]
cat = gs1.GraphicsStyleCategory
linePatternId = cat.GetLinePatternId(GraphicsStyleType.Projection)
linePattern = LinePatternElement.GetLinePattern(doc, linePatternId)
OUT = linePattern
thomas
Update: One thing I have discovered is this issue seems to only happen if the built-in Solid line style is applied. However, I would still expect the GetLinePattern to return a LinePattern object, especially based on what the API documentation states.
EDIT: This must be the problem; the LinePatternElement.GetSolidPatternId() remarks state "Note that Solid is special. It isn't a line pattern at all -- it is a special code that tells drawing and export code to use solid lines rather than patterned lines. Solid is visible to the user when selecting line patterns."
Given that the Solid line pattern is the only built in line pattern id (I believe) can I request the API documentation for LinePatternElement.GetLinePattern is updated as it is misleading if I'm not mistaken.
Sean_Page
I am glad I ran across this post, as I am experiencing the same thing, and I was rather confused why a valid Id wasn't returning an actual element.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
