Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Polar function like in Autolisp
5 REPLIES 5
adcdao
286 Views, 5 Replies
Hi everybody,
I 'm looking for a function to find a point from a start point giving a distance and an angle like the polar command in Autolisp for AutoCAD?
Thank you!
André
5 REPLIES 5
RPTHOMAS108
in reply to: adcdao
There are many ways of doing this
You can do it via Transform.CreateRotationAtPoint and then use Tranform.OfPoint
i.e.
TransformR = Tranform.CreateRotationAtPoint(XYZ.BasisZ, Angle, Pt_A)
PtB = TranformR.OfPoint(Pt_A + (XYZ.BasisX * Distance))
You could use Transform.CreateRotation with Tranform.OfVector:
i.e.
TransformR = Tranform.CreateRotation(XYZ.BasisZ, Angle)
Vec = TranformR.OfVector(XYZ.BasisX)
PtB = PtA + (Vec * Distance)
You can also work out X,Y location via trigonometry but then you have to adjust for quadrant of angle and would also have to consider 0 (horizontal) & 90 (vertical) special cases separately.
adcdao
in reply to: RPTHOMAS108
Thank you for your answer, unfortunately it's not working.
Both solutions are not working on all orientations (see the image, I'm trying to draw walls along the green lines with a length of 10' using endpoints in both direction. The bottom walls are correct but not the upper ones).
Here's my code:
//Get points and set distance
XYZ startPoint = uidoc.Selection.PickPoint("Start point:");
XYZ direction = uidoc.Selection.PickPoint("Pick another point for the direction:");
double distance= 10;
//Get angle between points
XYZ vector_from_pt1_to_pt2 = direction - startPoint;
double angle = vector_from_pt1_to_pt2.AngleTo(XYZ.BasisX);
//Transform
Transform transformR = Transform.CreateRotation(XYZ.BasisZ, angle);
XYZ vec = transformR.OfVector(XYZ.BasisX);
XYZ endPoint = startPoint + (vec * distance);
//Creating walls
Line geomLine = Line.CreateBound(startPoint, endPoint);
Wall aWall = Wall.Create(doc, geomLine, doc.ActiveView.GenLevel.Id, false);
Thank you,
André
adcdao
in reply to: adcdao
Now it's working,
The problem was the angle, AngleTo always return shortest angle so when Y of the direction point is lower then the start point I have to recalculate the angle,
Here's my revised code:
if (direction.Y < startPoint.Y) angle = 2 * Math.PI - angle;
//Transform
//Creating walls
Thank you,
André
RPTHOMAS108
in reply to: adcdao
To be honest you don't need to involve angles at all for this task. They just add a complication you don't need.
If you are picking two points then you have the direction vector and the first point is the origin. If you normalise the direction vector you can multiple it by the length you want along that vector from the origin.
Similarly if you are picking lines to draw wall along then you have:
Nearest endpoint of line picked, furthest line end from pick to form direction, then just normalise vector and multiple by length you want from end nearest pick.
RPTHOMAS108
Below forms 10ft line in direction from  Pt0 to Pt1 (three lines of code for what you need):
Dim V As XYZ = (Pts(1) - Pts(0)).Normalize
Dim Length As Double = 10
Dim L As Line = Line.CreateBound(Pts(0), Pts(0) + V * Length)
When using PickPoint it will pick the points on the current work plane for the view. If no such plane is set then an exception will be thrown (InvalidOperationException). Sections and elevations will generally not have a plane set.
Full example
Public Function Obj_220624a(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
        Dim IntUIApp As UIApplication = commandData.Application
        Dim IntUIDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim IntDoc As Document = IntUIDoc.Document
        Dim IntAcView As View = IntUIDoc.ActiveGraphicalView
        'Set sketch plane (required for picking points if no plane set).
        Dim SKP As SketchPlane = Nothing
        Using tx As New Transaction(IntDoc, "Sketch plane")
            If tx.Start = TransactionStatus.Started Then
                SKP = SketchPlane.Create(IntDoc,
                              Plane.CreateByNormalAndOrigin(IntAcView.ViewDirection, IntAcView.Origin))
                IntAcView.SketchPlane = SKP
                tx.Commit()
            End If
        End Using
        Dim Pts As XYZ() = New XYZ(1) {}
        Try
            For i = 0 To 1
                Pts(i) = IntUIDoc.Selection.PickPoint()
            Next
        Catch ex As Exception
            Return Result.Cancelled
        End Try
        Using tx As New Transaction(IntDoc, "Line")
                IntDoc.Create.NewModelCurve(L, SKP)
                tx.Commit()
            End If
        End Using
        Return Result.Succeeded
    End Function
Forma Design Contest
Rail Community
