Pointcloud section box
noushadcmpkl
noushadcmpkl
Dear Cummunity,
    I am trying to cut pointclouds using a PickBox input from the user. where user will be able to see only a portio of the pointcloud within a section box. I have tried some C# codes in RevitAPI. I am new to programming and I am having problem putting together the code. Kindly check the below code and please help me to run this code successfully.
Thanks in advance,
Noushad Khan.
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.PointClouds;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace RevitDev
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
public class PCSectionBox1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
private void PromptForPointCloudSelection(UIDocument uiDoc, PointCloudInstance pcInstance)
Application app = uiDoc.Application.Application;
Selection currentSel = uiDoc.Selection;
PickedBox pickedBox = currentSel.PickBox(PickBoxStyle.Enclosing, "Select region of cloud for highlighting");
XYZ min = pickedBox.Min;
XYZ max = pickedBox.Max;
//Transform points into filter
View view = uiDoc.ActiveView;
XYZ right = view.RightDirection;
XYZ up = view.UpDirection;
List<Plane> planes = new List<Plane>();
// X boundaries
bool directionCorrect = IsPointAbovePlane(right, min, max);
planes.Add(app.Create.NewPlane(right, directionCorrect ? min : max));
planes.Add(app.Create.NewPlane(-right, directionCorrect ? max : min));
// Y boundaries
directionCorrect = IsPointAbovePlane(up, min, max);
planes.Add(app.Create.NewPlane(up, directionCorrect ? min : max));
planes.Add(app.Create.NewPlane(-up, directionCorrect ? max : min));
// Create filter
PointCloudFilter filter = PointCloudFilterFactory.CreateMultiPlaneFilter(planes);
Transaction t = new Transaction(uiDoc.Document, "Highlight");
t.Start();
pcInstance.SetSelectionFilter(filter);
pcInstance.FilterAction = SelectionFilterAction.Highlight;
t.Commit();
uiDoc.RefreshActiveView();
private static bool IsPointAbovePlane(XYZ normal, XYZ planePoint, XYZ point)
XYZ difference = point - planePoint;
difference = difference.Normalize();
double dotProduct = difference.DotProduct(normal);
return dotProduct > 0;
SONA-ARCHITECTURE
You must call the void PromptForPointCloudSelection wuth good arguments :
Check this :
        UIApplication uiApp = commandData.Application;
        UIDocument uiDoc = uiApp.ActiveUIDocument;
        Autodesk.Revit.ApplicationServices.Application app = uiApp.Application;
        Document doc = uiDoc.Document;
        //Define a Reference object to accept the pick result.
        Reference pickedRef = null;
        //Pick a point cloud instance
        Selection sel = uiApp.ActiveUIDocument.Selection;
        pickedRef = sel.PickObject(ObjectType.Element, "Select a point cloud instance");
        Element elem = doc.GetElement(pickedRef);
        //Test if point cloud instance is selected
        if (elem.Category.Id.IntegerValue != (int)BuiltInCategory.OST_PointClouds)
            TaskDialog.Show("Revit", "Please select a point cloud instance !");
            return null;
        else
            PointCloudInstance my_pci = elem as PointCloudInstance;
            PromptForPointCloudSelection (uiDoc , my_pci)
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
@SONA-ARCHITECTURE Did you make your plugin available (SONA API)? I am trying to do the same thing through Python without a good result. Any advice?
