Hi All
Thank you for reading my post.
I recently upgrade my plugin from net framework to net core to support Revit 2025. However, I experience the issue where Revit could not load the Autodesk.Forge v.1.9.9. The error message is in the illustration below. If I downgrade the version of Autodesk.Forge to v1.9.3, which matches with the one in Revit 2025, it does not show the error but I am not sure if there are any malfunction possibilities since I do not test thoroughly.
My current plugin with net framework works fine with Autodesk.Forge v1.9.9 for Revit 2023 and Revit 2024. Since my plugin targets multi version of Revit, I am trying to use the same version of Autodesk.Forge for all versions.
Please help.
