Please share the process to merge C++ plugins from Autodesk 2016 to Autodesk 2022.
rishabhs3
rishabhs3
We have several plugins working in C++ with Autodesk 2016 so now wants to have these plugins working on Autodesk 2022 by upgrading Autodesk version. Please share the complete procedure for this.
Please share complete details of Autodesk Revit tool.
rishabhs3
I am still waiting for reply from Autodesk expert side. Anyone from development side can reply on this topic?
CGBenner
@rishabhs3
Welcome! What product are you using? Autodesk is the company name and there are many software titles.  Once I know what product you are using, I can move this post to the correct forum so that you might find an answer.
Thank you.
Chris Benner
rishabhs3
I have a c++ plugins and want to test in autodesk revit 2022 tool so what are the steps for this?
jeremy_tammik
This is the correct forum for discussing migration of Revit add-ins.
All Revit add-ins are pure .NET based class libraries and independent of the programming language used, so the steps for a C++ add-in are the same as for C# and other languages.
You can check the list of What's New in the Revit API posts to determine what changed in the Revit API from one release to the next and apply modifications accordingly:
https://thebuildingcoder.typepad.com/blog/2021/04/whats-new-in-the-revit-2022-api.html
In most cases, no modification is required at all.
Between Revit 2016 and Revit 2022, however, one significant change that cannot be ignored is the .NET framework version; the Revit 2022 API requires the Microsoft .NET Framework 4.8:
https://help.autodesk.com/view/RVT/2022/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
Other changes are probably minor and depend completely on your code.
