Please check this code for Getting Family Parameter GUID
KCIM_고영빈
KCIM_고영빈
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.ApplicationServices;
using System.Collections.Generic;
using System.Linq;
using System.Security.Cryptography;
using System;
namespace NewJeans
    [Transaction(TransactionMode.Manual)]
    public class ExtractSharedParamsGUID : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            Document doc = uiDoc.Document;
            Application app = commandData.Application.Application;
            List<string> result = new List<string>();
            var familyInstances = new FilteredElementCollector(doc)
                               .OfClass(typeof(FamilyInstance))
                               .Cast<FamilyInstance>()
                               .ToList();
            List<Family> families = familyInstances
                            .Select(fi => fi.Symbol.Family)
                            .Distinct().ToList();
            foreach (Family fam in families)
                Document famDoc = doc.EditFamily(fam);
                FamilyManager fm = famDoc.FamilyManager;
                using (Transaction trans = new Transaction(famDoc, "ExtractFamilyParameter"))
                    trans.Start();
                    foreach (FamilyParameter p in fm.Parameters)
                        string name = p.Definition.Name;
                        string defType = p.Definition.GetType().Name;
                        if (p.IsShared)
                            if (p.Definition is ExternalDefinition extDef)
                                string guid = extDef.GUID.ToString();
                                result.Add($" {fam.Name} - {name} : Shared, GUID: {guid}");
                            else if ((p.Definition is InternalDefinition intDef))
                                string type = intDef.ToString();
                                result.Add($" {fam.Name} - {name} : Shared, but {type}");
                        else
                            result.Add($" {fam.Name} - {name} : Not Shared");
                    trans.RollBack();
                famDoc.Close(false);
            TaskDialog.Show("Shared Parameters", string.Join("\n", result));
            return Result.Succeeded;
this is the code and result is
I correctly added the Shared Parameter to the family("shared2", "shared@").
When I access the parameter in the API, it shows up as InternalDefinition, even though the IsShared property returns True.
Has anyone encountered this issue before? What am I missing? How can I ensure that the Shared Parameter is recognized properly as a Shared Parameter in the API, rather than an InternalDefinition? please.... Help me
jeremy_tammik
Little side note: this command can probably be run in read-only mode, with no transaction. I always prefer read-only TransactionMode when it is possible. Please try it out and let us know whether that works as well.
jeremy_tammik
It seems to me that Gemini captures, understands and explains the issue quite well. Please check this answer and let us know whether it helps resolve the issue:
KCIM_고영빈
That was incredibly helpful...!! Your answer helped me so much
