Plates inside connection ID
rodrigo_vazquez_2LWX2PPNBWBU
Hi, I'm working with dynamo to make schedules as I need them, so I need to have a multicategory schedule to have all the structure weight. I am transfering the values of the plates paremeters as thickness, width, etc. But the problem is that when I try to select the plates through dynamo it is impossible.
Trying to understand what is happening I realize that the plates inside a connection dont have an ID, so I'm starting to realize that maybe it is actually impossible.
Does anyone know if it is possible or if I need to look for a work around
Luffy11
Hi @rodrigo_vazquez_2LWX2PPNBWBU , can you explain in more detail the point "The plates inside a connection don't have an ID"?  Is it a sub-component of a family or something?
