Plan not listed when Propagating Grid
I'm new to Revit and currently learning how to use the program.  I'm looking to populate the drawing with column footings, and would like to use the column grid from the 1st floor.  When I attempt to use the Propagate datum extents, the view I want to apply to isn't listed.  Anyone have an idea what I should do?
jeremytammik
Do you mean manually, through the user interface?
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to product usage or end user support issues here.
You should try the Revit product support discussion forum instead for that.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Sorry, I posted this in the wrong forum. Thank you for pointing that out.
jlucero
I'm looking for the same answer. Where did you post this question?
