Placing a Linear Dimension object on Family Instances
jmadeley37KVE
jmadeley37KVE
Hi all,
I need to place a Linear Dimension on a series of Family Instances using the Revit API but can't seem to figure it out.
I need to get the Geometric References from the Instances but can't seem to get it right. The location property in this case are LocationPoints but I can't seem to make these ReferencePoints.
If anyone can help I would really appreciate it 😄
Jack
jeremy_tammik
Dear Jack,
Maybe you can check first whether you can retrieve any useful references either from the FamilyInstance itself or from the geometry returned setting Options.ComputeReferences = true:
Good luck and best regards,
Jeremy
jmadeley37KVE
Thanks Jeremy!
After reading your links I realised I need a Geometric Reference rather than an Element Reference to add to the ReferenceArray for the Dimension. I found a mixture of point and line geometry instance references from the FamilySymbol's i'm using and have managed to get it to work!
Thanks for all the help 🙂
